what size in pixels do images have to be to fill the screen as wallpaper?
thanks
thanks
The screen is a QVGA - 320x240.
if i send a photo with a pixel ize of 320x240 it still does not fill the screen as wallpaper though?
I see what You want... No way. The picture only fit all screen, only if is part of theme. You need to make a theme with that picture.
how do i create a new theme as the ones on the phone dont make the picture full screen?
There is a dedicated application for that on Forum Nokia. Download and work with that. Is very user friendly.
is there a link please?
Or try, 340x324 is not full screen but fitts in between,because it is a symbianphone you cant make fullscreen wallpapers.
Try 240x234 😊
i know you cant make it really full screen but at the minute there is a little bit at the top of the photo and at the bottom that the photo is not covering so just wondered what size i needed to make photos to cover this bit to?
I use 240x240, fits perfect between the softkey menus and the "clock bar".
240x240 works but looks a little stretched top to bottom.
is there another size that will still fill the screen like 240x240 but wont look stretched?
bradfordlad wrote:240x240 works but looks a little stretched top to bottom.is there another size that will still fill the screen like 240x240 but wont look stretched?
Read wat brockenX said! 240x234
[QUOTE=rooie60]Read wat brockenX said! 240x234[/QUOTE
Sorry something did go wrong by clicking
thank you
even 240 by 234 looks a little stretched. suppose its just the screen size. As photos taken normally dont have the ratio, so have to be squashed to fit the screen.
I re-size my wallpapers to 350x320😎
And they look great:icon14: :tongue:
