Can I change my alarm sound? The basic sound is so boring. Any ideas.
can I change alarm sound
There is a applications for that. Called ExtendedProfiles or WorldClockPro
with those you can change the sounds. Those are made by PsiLoc.
You should really try the search on top right of page.
This has been discussed previously, even today. :-?
i got them proggys dude and i still cant change the alarm tone it says its changed but when the alarm goes off still the old one ?? let me know if you have better luck :P
[quote="xzibit"]i got them proggys dude and i still cant change the alarm tone it says its changed but when the alarm goes off still the old one ?? let me know if you have better luck :P[/quote]
yup, yup, same thing happened to me. im using wolrd clock pro. 8)
I have uploaded this aplication into my N7650 and there is no problem... It works great... I use this alarm every day and as I say. NO problem...
Try Smart Profiles from www.symbianware.com!
