hi 2 all! guys 1 of my friends has a n3230 and that thing has an awfull feature! it beeps b4 ringin wen some1 calls and he hates it!has n e 1 known n e thin bout it !we wanna stop it!is there a program or we gotta do some configurations?thnx alot 4 your helps!
3230 beep sound
I had one, and never notest that. Do a firmware upgrade, and / or right now try change the sound and see if the problem still exist.
I had a 3230 and that beep was really annoying. It plays before any sound when receving a call, SMS, even after booting. The only way to remove it is to make a firmware upgrade, as nj7 said.
Hi ' I Got One 3230 But He Start Up Problem . Can Seter ? Thank
I don't know why you people are facing problems. I could see the controls to stop the starting beeps in the menu. And about beeps you can turn off that feature.
With regards,
Mandar Thosar
somebody plz give the link 4 new firmware........
that beep is too bad........
