Hello everyone, I just got a Nokia N80, absolutely loving it.
Couple of questions though...
How can I change the tone for an SMS? I'm not talking about the standard nokia ones, but say to a short mp3 tone or voice recording etc??? Is this possible?
Another question..is it possible to make the wallpaper take up the whole screen? I've got some crappy logo in the top right hand corner of my service provider and its pissing me off!
How do I put more options in my GoTo menu? As it stands I only have 3 things in it...
Any help I would be VERY thankful for...Cheers!
Ahhhh! Someone help me..these things are really frustrating me..particuly the GoTo Menu problem and the SMS Tone 😞
http://www.allaboutsymbian.com/forum...t=message+tone
The link above tells you how to do it. You have to use nokia PC suite and drop ur new message tone into the folder mentioned. ( c and E being folders on ur phone not ur pc hard drive)
Make sure your desired mp3's are stored in C:\Data\Sounds\Digital or in E:\Sounds\Digital
Then when you go to Menu > Tools > Clock > Settings or Menu > Tools > Profiles you should see the relevant mp3 files appear in the list for selection.
Cheers mate thanks heaps. I'll try it out when i get home.
Anyone know anything about adding more things to the Go To Menu?
BucketsJackson wrote:Anyone know anything about adding more things to the Go To Menu?
Can't be done. Seems to be a fudge of an app
