is there anyway that i can directly recieve the file i am taking via bluetooth in my mmc as i cant recieve a file bigger thn 4 mb because of the availalble fone memory of my fone. it is filled due to programs like lifeblog n nokia sensor...and antivirus.
also is there any such antivirus which installs on memory card n can be updated using a pc as i donot hav wap
direct recieving in mmc in bluetooth transfer
Yes. Install MSDriveE.sis, and the memory becomes the Card.
nj7 wrote:Yes. Install MSDriveE.sis, and the memory becomes the Card.
it might not work (doesn't work for me, at least) if it doesn't work for you then AFAIK you need to have the software updated (nokia point...)
I had the oldest firmware on my old 3230 and MsvDriveE worked from the first shot.
yeah...it works fine..thnk u
hello,
can anyone send the link for the same software.I eed it very badly.
regards,
shankar
Is already posted on this forum. I don�t know exactly where, but do a little search... maybe on N-Gage forum, and You go find.
Actually is right on this forum. Twice.
here is the link
http://depositfiles.com/files/311097
