Help!
4 replies · 1,215 views · Started 17 October 2006
I finally got a card reader and a couple of MMC cards for my QD.
One of the cards formatted fine, I transfered some games onto it via the card reader but the QD didn't recognise that anything was on the card.
The other card was corrupted. I used Partition Manager to play around with it, but it still comes up as corrupted and the QD won't do anything with it.
In the meantime, my PC's now not recognising the MMC drive of the card reader.
Starting to get annoyed now...
Help anyone?
Try the format process inside N-Gage. After that, remove the card, and with card reader made de copy of files.
hey bro.... try to formate ya card (PC) under formate FAT. (not FAT32)
wat games r ya put it in..... ngage...or sis or jar ....
if ngage... problem with libs.files....
if sis... pls reinstall it agian by using ngage phone.
jar.... was easy... mostly under (midt) should be no problem...
p/s make sure, when ya put it file/games..remember
to let it run finish and Eject MMC b4 taken out....
if ya need more about tutorial Ngage games... got to ....
http://www.allaboutsymbian.com/forum//forum/thread/52244/&page=2
if dis problem still the same... the problem was ya ngage phone...
coz auto unlock mmc..... reformate ya phone ok.
regards.
Thanks guys.
One of the problems I have is that my card reader isn't being recognised by My Computer, the other drives (SD, MS, etc) are there, but the MMC drive isn't. It used to be visible as Drive H, but now all I've got is Drives I, J & K. This is obviously a problem as I can't communicate between MMC and PC.
Bizarrely, Partition Manager seems to recognise the card as I've deleted and added partitions, etc, but to no avail.
I was getting so excited about playing with my NGage...
try to unplug other usb...conection..
then restart...if still problem....
probaly was de card reader... coz if ya ngage can detect it...
enjoy.
