Hello all,
I'm very interested in getting the N80. We are using GoodLink for our our corporate email with Microsoft Exchange. I was wondering if anyone has tried to run GoodLink on the N80? The E61 is supported by GoodLink so I'm assuming it would work?
Got GoodLink???
...also, has anyone been able to use any push email software on the N80?
The OTA installer just exits when I try and run it.. my guess is they don't support the N80 yet 😊 you can go to http://get.good.com and download it yourself.
floodland wrote:The OTA installer just exits when I try and run it.. my guess is they don't support the N80 yet 😊 you can go to http://get.good.com and download it yourself.
Thanks that exactly what I needed to know. Hmm, that's unfortunate. I was hoping it would work.
Sorry to revive this thread from the dead but has anyone tried to install the latest version of GoodLink on the latest N80 firmware on on the N80ie?
Well.. I tried to install it every which way possible but it doesn't work. Goodlink might consider supporting it if there is enough customer interest. If you want Goodlink on N80 please let them know 😊
Hello,
I got the same problem on the E70.
It should work, but I may not install the Goodlink SW. "This phone is not supportet".
Does anyone have a workarround?
Thank you
& rgds from Germany
die 52
Unfortunately.. no work around. Unless there is someone out there who can reverse engineer the OTA sisx installer file and bypass the part where it checks what phone you have.
I spent a few days trying to install it with the help of Goodlink tech support. Event the phone is unsupported they still tried to help me. We tried everything... OTA setup, mem card setup, cable/cradled setup from the Goodlink console.. nada...
Only way it will work is if Goodlink modifies the installer - which basically means we have to wait for them to support the phone.
