I have an N73 and 2G card, works fine.
I added MP3's to the Sounds-> Digital folder, and they all appeared in the music player. So I added some more, but the new ones don't appear in the music player.
I can see them in File Manager, and even play the files (which opens the music player to play them!) but when I go back into the music player they aren't there!
How do I refresh the Music Player to re-detect what songs are on the flashdisk?
I have tried taking the disk out, re-inserting, etc.
Help!?
Rack1600 wrote:I have an N73 and 2G card, works fine. I can see them in File Manager, and even play the files (which opens the music player to play them!) but when I go back into the music player they aren't there!
Help!?
I had the same problem. It 's very simple. Go to Music Library and then select UPDATE MUSIC LIBRARY. The newly copied MP3 files will then show up.
uh, yeah, I dont' know how I missed that, but I did... cheers. My bad. Still, my K750 used to do it automatically when you copied into the music directory.
