OK, so I just did the v4 upgrade using the software updater, all good. One problem, and its a doozy. I left my memory card in when I did the update (my brother did and it worked alright for him, although he later informed me he doesnt have much installed on there, whereas I do). Anyway, now every time I restart (or put the mem card back in), it says "Installing" for about 3 minutes while it tries to instll suff from the memory card. After that time it fails and says "Unable to install remaining applications, to install go to Application Manager".
Problem #1 - I got to App. Manager (which take AGES to load), and it lists a whole heap of jibberish programs (like 20003cfb.sis and the like) which say "Not installed". 20003cfb.sis is the first in the list, I cant delete it so I try to install it. It asks me if I want to Install KeypadLock? I say yes. Bang, File Corrupted! So I thought I would format the mem card from the phone.
Problem #2 - I copied everything on my card across to a folder on my PC with the intention of formatting the card. "Unable to format memory card, card in use by another application". (There is nothing running, I'm guessing the thing thats trying to install when I boot up is still running somewhere). So, I thought I would format on the PC using the card reader.
Problem #3 - It does weird stuff here, it tells me the card capacity is 3.83GB (its 2GB), I try to go ahead anyway. No can do. Write protected. Wtf?
So I just manually delete everything using PC Suites File Manager. Its all gone now except a folder called "Data" (can't be deleted). Which has a sub folder called "NEF" in it, in there is a file called NEFConfig.xml and another folder called "Log". Thats it. Interestingly my Java progs are still showing up as installed in App manager (but they arent working). So I try to format again both ways.
Problem #4 - Still nothing, cant do it. How do I stop it trying to install these non-existant programs?!
Software updater never told me I ad to rmove my card which makes this all the more frustrating.
I think that cvers everything Ive tried to date. Ive been at it a while now, any ideas would be appreciated.
