hello, I have an nokia e61...
Whenever I run a java app. i get no sound:con? it is really whit all java applications\games. :s
Is there some setting or els that is needed to be enabled..?
Hi there,
I have a couple of java apps (games) on my E61 and they all have sound. So it should work. Are you sure your sound is turned on or you're not using the silent profile?
Wouter
wouterk wrote:Hi there,
Wouter
Problem fixed :icon14:
It wasn't the profiles. i don't know what it was.. but i restored the phone into system factory settings and everything seemed fine..
tnxs for the reply😊
You're welcome. 😉
Wouter
