Help#2-Application installer problems
3 replies · 4,587 views · Started 18 October 2006
Help!! i cannot install any programs onto my p990i using SE pc suite for smartphones' application installer. i get an error code and the message 'application threw an error', then, if i try again i get 'access denied' message and code 8007005. i have tried to update the phones software as that may be the problem but SEUS isn't working (see my first thread!) any ideas as i've got the software from my p910i waiting to be installed and it's sooooo frustrating. please help, thanks. Tim.
A little bit of research would have shown you that the P990 uses UIQ3 and not UIQ2.1 therefore P910 apps do not work on the P990. Please visit any online store for Symbian s/w and you'll see that the UIQ3 apps are seperated from the UIQ2.1
Ta for that. i wont bother trying to install them but i do have apps for the p990 which i cant load either. i still get the error codes with them, any ides?
@timreeves
mate you may have corrupted data on your P990 or on the Duo card. Sorry but the best cure is:
1. Format the Duo card (don't worry as the Try-buy apps are available on the SE web site)
2. Perform a Master Reset (tools>control panel>other>master reset PIN is 0000)
3. Reflash
Now try to install the UIQ3 apps. The Master Reset is needed as the reflash does not delete all the systems data and if this is corrupt a reflash is not that helpful.
