Hi'
Just felt over a Search app, probably from the E50. Works like a charm on my E61, and probably on other E-series also.
Search in:
Messages
E-mails
Calendar Events
Contacts
Other files
To-dos
Notes
Hi'
Search in:
Messages
E-mails
Calendar Events
Contacts
Other files
To-dos
Notes
bobby68 wrote:Hi'Just felt over a Search app, probably from the E50. Works like a charm on my E61, and probably on other E-series also.
Search in:
Messages
E-mails
Calendar Events
Contacts
Other files
To-dos
Notes
Great, just tried this, otherwise works like a charm, but I'm using a 3rd party pushmail service (Seven), and unfortunately the Email search doesn't cover the "Seven Mail" folder which holds all my emails. Any way to configure this?
bobby68 wrote:Hi'
You're right. It's excellent isn't it? Thanks for the tip.
Fine on E70 in landscape and portrait mode.
Nice one
Wonderful! Thanks for pointing this out! :icon14:
How does this work when installed in other S60 3rd phones? Once you install it, where in the menu can you access the search functions it brings?
It's a separate application rather than a function. You can stick it where you like 😮
It works well - lets you choose where to search (all, messages, contacts etc).
I use it to check phone numbers on my bill to see which calls/texts are chargeable to my company.
