N6680 - Phone Needs to be Reformat
4 replies · 3,186 views · Started 21 October 2006
Hi! could anyone pls help me about this thing? I have my cell phone N6680, i think it got viruses. I searched over the Internet how to download a software about formatting N6680 but i haven't got one. Pls help me what is the software that i would use to format my phone so that i can download it and one for myself. thanks...
Theres no need special software to format, just do an Hard format that way: * + 3 + Green Key and power on. Way untill format appears on screen. You lose everything inside:icon4:
nj7 wrote:Theres no need special software to format, just do an Hard format that way: * + 3 + Green Key and power on. Way untill format appears on screen. You lose everything inside:icon4:
What will be losed if i key in the code? Or what is left in my phone? Pls reply. Thanks!
You'll lose all the data stored in phone's memory. I recommend you to do this without MMC inserted. Do it whith the phone plugged to charger.
After formatting the device, it will be in the state it was in when it left the factory where it was made (fully functionaly, but as if it never has been used; no personal data/information, just factory default state and content).
The sequence will not touch the memory card or SIM contents.
