pls reply
6 replies · 4,222 views · Started 21 October 2006
ti im a new member can you help me on my nokia 3250 my problem is when i select sound clip video clip images and etc. there is an error messege appear
"Unable to execute file for security reasons" can you help me here plss what should i do? tnx 😊
Try to change the extension of that file into .sis and see what happens then. It might be malicious apps with extension changed as in sound/video/pictre files.
Jawo wrote:ti im a new member can you help me on my nokia 3250 my problem is when i select sound clip video clip images and etc. there is an error messege appear
This is because your phone memory is very low. This has nothing to do with your Memory card. Try to delete or move as much data possible from Phone to MMC. This should solve your problem.
