Display flickers if power cord is in?
8 replies · 2,510 views · Started 21 October 2006
My screen begins to flicker if i put the power cord in my phone (N80). It stops not until i put the cable off.
What could be wrong?
Thomas
You are supposed to switch off your phone when you charge it. Apparently it damages the battery.
No need to switch off the phone when charging. There should not be any display flickering when charging; either the phone is broken, the charger is broken, or something's wrong with the electricity supply to the charger.
The last two can be eliminated by using a different charger and trying to charge in some other location (use a different wall socket, different room, different building).
Mine does the same - it's like a feint pulsing of the display brightness when it's charging, with a frequency of about once per second.
I've never worried about it.
Graham
James761 wrote:You are supposed to switch off your phone when you charge it. Apparently it damages the battery.
No, you're quite wrong.
You're supposed to remove the battery before charging the phone. It can damage it otherwise.
For the record, mine does this too. Ah well.
N/A wrote:No need to switch off the phone when charging. There should not be any display flickering when charging; either the phone is broken, the charger is broken, or something's wrong with the electricity supply to the charger.
I have owned 3 N80's all of which had a minor flicker when charging. It's nothing to worry about and barely noticeable. This does not indicate a fault, and there is no need to power off any mobile phone when charging it.
However, your advice about trying charging in another room or a different socket is very good advice. Thanks.
Dez
TimmyRaa wrote:No, you're quite wrong.
I am confused, how can you charge the battery if it's removed from the handset, and you are using the standard supplied Nokia charger?
Dez
my n80 also does this wen charging, so far iv used all the FW versions and it does it with every version, its nothing to worry bout
