RealPlayer error
1 replies · 2,174 views · Started 22 October 2006
Whenever i open a realplayer file, it says 'Unable to play either sound or video clip. Trying to play partially' - and then the audio starts up w/o the video
I've tried several different files dled from several different sources, but still no luck
Any help would be greatly appreciated!
I think the files your trying to use are not compatible with the N73 real player
wat file format are these files whats their resolution, bitrate, compression
Nokia phones tend to be very picky you might need to convert the files
