hi guys i have a nokia n80 and theres a really annoying symbol in the top right corner of the screen. I know it is not the wi-fi thing 100%. The symbol looks like a straight line and has an arrow pointing upwards. I have tried everywhere to find out what this means but i cannot find anything!!! Any help greatly appreciated thanks
really need help!!!!
screenshot would be nice, but I assume it's missed calls?
Yes, it's missed calls. It'll appear after you've cancelled the missed call(s) message on the idle screen and will stay there until you 'view' the call in the calls log.
either that or its a message in the outbox trying to send.
ffs RTFM
if its a missed call item just go into your call log for missed calls look at them then select back all the way back to your home screen , the sysble should go then 😊
Keydogg wrote:either that or its a message in the outbox trying to send.ffs RTFM
Now you mention it I read the description again and it does sound more like something stuck in the outbox. The missed calls icon is more, erm, slanty.
Mmmmm.... slanty.
Yes, you have a message stuck in outbox, just delete it, the icon will go away.
Hardeep1singh wrote:Yes, you have a message stuck in outbox, just delete it, the icon will go away.
Ive not had txt get stuck on my n80, but on my last s60 phone (6680) when they got stuk i found putting the phone offline then back online sorted the problem and the message was sent
if theres nothing in the outbox, change the message memory to phone or to memory card depending what its set at and see if theres one in the outbox through the alternate memory
I assume You already search on User Manual, so post an image!
