Countdown Timer App?
11 replies · 40,261 views · Started 23 October 2006
Hi all
I wonder can you advise me, on my old 6680 I used the egg timer countdown app quite a lot, but it doesn't seem to be compatible with v3 unfortunately...!
Can anyone recommend a freeware countdown app that will work on my N73 please, I can find a few commercial software packages which do loads more things, but all I need is a countdown function...
Any help gratefully received..!!
M
Thanks for that, but I need to buy them, I would prefer a freeware simple timer app, any thoughts and / or links?? Much appreciated
M
Great little app, I just wish I coudl have it in my apps folder but at least I know I can have a countdown again, thanks heaps...
JP
PS: I'm only using on an N73 too...
It's made in flash. Converted to Flash Lite from a similar thing i've made.
Put the file in the folder "other" and it will show up when you start the Flash app. I have the flash app on my startscreen for easy access to the timer.
Cheers.
it works on my N73 !!! 😊 excellent app, specially the 'beep' in the last 10 secs.
may be asking too much, but is it possible for you to make a stopwatch for N73(or i'm blind and couldn't find stopwatch in my n73) ??
anyway, thanks man.
Hi Jonne,
I have tried your software on a 6120 Classic. It works well - I run a guest house so I need the coutdown timer for eggs in the morning!
Cheers
Paul
jonne wrote:It's made in flash. Converted to Flash Lite from a similar thing i've made.
Cheers.
How do you stick it on your startscreen?
