MMS limit
8 replies · 2,603 views · Started 23 October 2006
Hi ok this is my first post,
What im after is a way to change the 100kb limit i have set on my Phone for sending MMS pic or vids.
Im on o2, on my old 6680 i can send way over the 100kb amount on o2 so why on this phone cant I.
Its quite annoying as you have to shrink the pic or make the vid really short.
Messaging > Options > Settings > Multimedia message
There change "Image size" to "Large" and "MMS creation mode" to "Guided" (or "Free"😉.
If that's not enough, then you're hitting a limit set by your operator on their servers (their MMS-C, Multimedia Message Service Center). Call O2's customer service and ask what kind of limits for MMS they have defined.
Cheers for the help, it unfortunately didnt work still says Unable to insert all objects Maximum messagesize 100kb
I think its the fone as it says this even before you put a name in or try and send it.
If I put my sim bak in my 6680 i can send way over the 100kb, its got me stumped, there must be something set in the fone.
There are options in the MMS settings for small, large and original. I'd try setting it to original if you haven't done so already. If you have, erm, that's me all out of ideas.
That I already explained in the first reply to this thread. Apparently it isn't/wasn't enough, so it must be either an O2 specific phone software (firmware) limitation, and not network related, if the device complains about the size even before sending the message.
