SIP via IP Passthrough (USB connection)
0 replies · 2,309 views · Started 23 October 2006
Hi ALL!
Is it possible to use Nokia E series SIP using IP Passthrough?
The problem is when I'm trying to adjust the SIP settings on my E60 it is impossible to choose IP Passthrough profile form the list. Only Wi-Fi/GPRS/EDGE appear. IP Passthrough connection is working.... but only not for SIP
It may occur cause of UDP/TCP incompatibility...... Maybe some additional software?
Thanks!
