few questions about the N73 Mini SD (Memory card) support
5 replies · 8,370 views · Started 23 October 2006
Hi all first thread here, hope I'll get the answers I was looking for.
I need to know few things about the mini sd:
1. If there is a size restriction to the n73 memory card (mini sd), in the N73 spec page (http://www.nseries.com/nseries/v2/media/product/tech_specs/en-R1/tech_specs_n73_en_R1.html?lang=en&country=R1) they say "Approx. memory capacity indication with 1GB miniSD memory card", meaning I can use max of 1gb ? , because I saw in some forums people say they use 2gb.
2. If there is a mini sd speed limit (x60, x80, x120...etc), or I can use all speeds of memory cards, and if there is any big differences between speeds (does the extra price worth it for faster cards)?
3. If all brand's of mini sd cards can work on the N73 or only nokia and sandisk?
4. I found this card "Kreton Mini-Secure Digital 2GB X120" in a reasonable price, if someone can tell me if the N73 can support it, or better if someone try it, and can tell me if it's work smoothly.
Thanks ahead for all helpers 😊
1. 2 Gb is the limit. No problem at all with 2Gb card;
2. Buy the faster You can. Advantage... more relative... because it can save photos or other things fast is tha card is faster;
3. All, seems with only kingston donne some problems;
4. I don�t know that brand.
Ok thanks I will wait for some more info maybe about the brand I want to buy, and if someone can elaborated on the card transfer speed I will be much grateful.
