Has anyone linked the M600i and scalix email server using the Exchange Client that comes from sony erricson. I have tried and it seems to talk to the server and login but then logout right away.
Has anyone done this or have any ideas.
thanks
George
You cant do that since Scalix does not use MAPI or Active Exhange. It does on the PC side uses a special plugin called Scalix Connect. The only option you have is just use IMAP4. Which does work quite nicely. calenders will not be synced for obvious reason. Nor you can use webcal to sync your calender because the m600i only talks vcal. renaming the file will not work.
hope that helps
