Small Icons for Java applications
1 replies · 2,815 views · Started 24 October 2006
I've noticed that the shortcut icons in the main menu for nearly all of my Java applications are much smaller than they should be; eg the icon is suqeezed into a tiny section of the available space and is so small that it's not really legible.
This doesn't happen with c++/native apps. Has anyone else noticed this? Any ideas why?!
Mucho thanks
Why: Because the Java app developer only supplied a small bitmap icon.
Fix: Ask the developer to make a bigger or scalable (SVG-T) icon.
Alternate fix: Change the icon in the .jar file yourself, before you install the app (look in the manifest file inside the .jar package).
