"e62 & Mini Sd Wifi Cards..."
2 replies · 6,082 views · Started 24 October 2006
Hello all,
I am new to this and wanted some advice. I have just purchased a Nokia E62 for Cingular wireless service and needed advice/direction from all you Nokia experts.
I am going out of the country in a week or so and need my phone unlocked so that I can use my international SIM card (I have service already established in the country I am going). Are there any websites out there that can unlock the E62? Also, I want to know if it is possible for the E62 to use a Mini SD WiFi card? If so, which kind and where can I buy it?
The ones I have seen out there stick out a little bit from the slot. Since the MINI SD slot is located under the battery cover, where do I find a WiFi card that will fit the slot and not STICK OUT and obstruct the cover from going back on the phone?
Any help would be great. Thanks all😊
Dunno if remote unlocking is available for the E62 yet. I guess not. But i could be wrong. The easiest way would be to ask the unlock code to your network operator. You might have to pay money for that.
No, you can't use a wifi mini-SD card in your E62 (or in any other symbian smartphone for that matter) because the E62 does not have an SD IO slot. It's just a normal mini-SD slot that accepts memory cards and nothing else. If you want wifi, you'll need to get an E61.
Hey All,
Does anyone know where I can score an E61 for a really good price? I have an E62 which I am trying to get rid of and replace with an E61 because it has the unlocked WIFI capabilities. If anyone out there knows of a site or dealer, please let me know...
Thanks...
