Taking a call TT6 N80
6 replies · 2,454 views · Started 24 October 2006
hi
is there any way to answer the call with loudspeaker on ???
i mean when the phone is ringing while using TT6 to answer the phone with loudspeaker activated straight away
thanks
not found one, the way i do it is:
answer call
hold menu (whilst saying 'hang on a sec'😉
select telephone
select loudspeaker
thanks for that
but still seems to be a lot of clicking
it would be nice to tak a call with loudspeaker on - maybe in TT7...
i have refined my method:
answer call
tap menu twice
select loudspeaker
gierach wrote:hi
thanks
I know this is not a direct answer to the question asked, but...
... do you know TT6 works OK with Bluetooth Headsets. You can have the BT GPS receiver and your BT Headset active at the same time, so you don't need to use the loudspeaker.
Sorry if the above info is not relevant. 😉
Dez
dez_borders wrote:Hi,
Dez
Hi Dez,
I have tried with the bluetooth headset and tomtom at the same time but this means that the tomtom instructions (together with an annoying bleep that cuts off half the instruction) are re-directed to the headset and I don't really want to wear it all the time.
Do you know if there is a way to route calls to the headset and instructions to the loudspeaker?
Thanks,
Dave
dave_a wrote:Hi Dez,
Dave
Sorry, don't know any way to achieve that. Let us know if you find a way! 😉
