Does NOkia 3230 support 1 GB MMC
1 replies · 1,911 views · Started 25 October 2006
Hi there,
Does Nokia 3230 Support 1 gb mmc or not? And can any one pls tell me which MMC type does it support either SD or DV card.
Works great with 1 GB. You need a RS-DV MMC (reduced size dual voltage multimedia card). Secure digaital cards (SD) don't work, although they are pretty the same, the pin configuration is different.
