I'm on my 2nd N80. the 1st one had a hardware fault with the secondary camera, I've just got this one out of the box and want to restore the data from my old one only to be greeted by a Unknown Device error.
If you go into device it shows up as an unknown device under the USB settings.
The wierd thing is the last one worked fine. no software has been changed.
Has anyone got any ideas on how I can get this working? As I can't find a XP N80 USB driver anywhere. 😡
Thanks in advance
