Hi
I have curiosity for knowing how would be programmed an application that will reverse given text. Thank you
symbian S60 Application
What do you mean with "reverse given text"?
Simply writing it backwards like this? ?siht ekil sdrawkcab ti gnitirw ylpmiS
Or do you mean something else?
Is this a perhaps some sort of a school project you want someone else to do for you?
Yes, I want this.
Do you know how I can make this?
Sure, but I'm not going to write it for you, but you can use Google to find string reverse examples:
http://www.google.com/codesearch
With even the most basic programming skills, you should be able to figure this out on your own (create a new string or byte/character array to hold the reversed string, and then go through the string/array you want to reverse from the end to the beginning and copy each byte/character one by one to the new string/array).
i don't find the code, please, can you help me?
What you should do is following:
void reverse(char* str)
size_t len = strlen(str);
int i = 0;
char* copy = malloc((len+1) * sizeof(char)); // In case char is not 1 byte
while(i < len)
copy[i] = str[len-1 - i]; // Copying in reverse order
i++; advance through the string
copy[i] = '\0'; // Null terminate string
strcpy(str, copy); // Store the result in the original string
free(copy); // Release memory
return; // Exit
if you need to store the original string you just do the memory allocation before calling the routine and routine should look like
void reverse(char* str, cahr* copy) - everything else is the same
Now this is the code you just need to add it to your application
Greetings,
elgrande 😃
