HEY CAN ANYONE TELL ME THE STANDARD PINCODES FOR N70
PLEASE EMAIL IT TO ME ON [email][email protected][/email]
N70 Stamdard Pincode
12345 is the standard/default lock/security code. The phone has no other "STANDARD PINCODES".
PIN, PIN2, PUK and PUK2 codes come from the SIM card provider = the network operator (or "carrier", if you are from the USA).
The default PIN most operators use is either 1234 or 0000 (and that is indepdent of the device). The PUK codes depend on the SIM card serial number (the IMSI).
And, you posted your question here, so you can also read the answer here (I'm not goint to email anyone privately).
N/A wrote:12345 is the standard/default lock/security code. The phone has no other "STANDARD PINCODES".PIN, PIN2, PUK and PUK2 codes come from the SIM card provider = the network operator (or "carrier", if you are from the USA).
thank you very much worked fine
