E70 - AT&T calling cards: How to set up automatic dial sequence?
1 replies · 3,846 views · Started 26 October 2006
HI Guys, I have an AT&T calling card I use for work. Frankly the AT&T service is disgraceful when utilising it for any numbers outside the usa.
I am looking for a way to set an AUTOMATIC proceedure or [B]CALLING CARD DIALING SEQUENCE to enter the AT&T card number[/B], the account and then the pin after dialing the number I need.
On the E70 (a new one) with the seemingly slower method of navigating to get DTMF working (compared to non simbian Nokias I have had) , I would REALLY like a way to do this.
Would someone provide some info on how to do this?
Many thanks
You can add DTMF "pauses" to any nokia phone by adding either "p" or "w".
So for example (using a calling card number)
0207 166 6200w323474783392
will dial the number and then ask you if you want to send the pass key number. You can put this within a contact if you like.
I have never tried nesting w or p
