When I am trying to install ultra mp3 player i am getting a message file corrupted and the installation exits automatically. Can any body help me in this.
File corrupted
Is it only this apps that fails? In other words, can you install other apps OK?
If so, make sure you have a version compatible with the 3230 (S60 2.1 = S60 2nd Edition, Feature Pack 1), and if the problem persist, contact the developer's support.
As it is a commercial app, they should be able to support you with their app. (I'm assuming that you are not a thief and haven't stolen the software.)
This is the problem only when i try to install mp3 players or smart movie player.THERE IS NO PROBLEM WHEN I TRY TO INSTALL OTHER APPS.
Do you have the McAfee Virus Scan? If yes, turn it off.
