Can you change the screensaver on Orange
3 replies · 2,812 views · Started 26 October 2006
Are you able to change the screen saver on an Orange N73 ... from what I can see, it seems that you can only change to a clock, or the default screen saver, which is the dodgy Orange one.
Please help .. I would like something a bit more interesting.
With the older Symbian handsets (my 6600, basically) you could only set screensavers as clock or "Default". It might be the same with newer ones too, meaning you'll need special software to set GIFs as screensavers :frown:
Yep, you'll need special software to change the screensaver to anything other than "clock". I disn't get a chance to test this on an Orange handset, but I think you can change the screensaver as you can on a vanila handset.
I tried the XXL Screen Saver software, but it does not seem to be compatible with the N73 ... is there any other software that will allow the screen saver to be changed?
