Does anyone know whether the Nokia 7650 supports the Epox Bluetooth Dongle?
It uses the Widcomm BT stack so it should work with no problems!
Yeh... i just got it. It works fine!
Only now im just having the problem where its not sending pics from phone to PC LoL.
Just trying the multiple solutions from other posts to see if it'll work.
Downloading the TECOM Bluetooth Software 1.2.2.16.msi so see if it works now.
Just try the AcceptOther registry tweak and it will probably work!
I also have the EPOX and the same problem!
Keep us updated if you find a way to make it work!
Also the registry "accept all" tweak doesn't work...
ive got it working now.
u need to
1) download TECOM Bluetooth Software 1.2.2.16.msi driver.
2) then set "acceptother" to "1" in both the HKEY_CURRENT_USER and also HKEY_LOCAL_MACHINE
It now works.
