N80 Orange V 4.0623.0.42 F/W upgrade
6 replies · 3,133 views · Started 27 October 2006
After reading the forum on the Nokia site regarding the ability to update from the .41 to the .42 firmware FOTA, the instructions advise to goto Connnect, device managers, options, search for updates! i have no settings within device management to allow me to do this, has anyone manged this on an orange n80 yet? if so could you post the server settings needed to be able to achieve this or point me in the right direction as to where i can get them, it does say contact service provider, but would rather slit my wrists than wait on the fone for an hour only for some gumby to ansa and not have a clue, apologies any orange employees, i work for vodafone and its as bad here!!!!!
After doing a search for updates yesterday, my phone said the .42 was available. As I was away from my PC I didn't want to download a huge file over GPRS. I tried using the WiFi at home this morning and it now says there is no updates available.... has it been pulled???:con?
mcsleazycrisps wrote:After doing a search for updates yesterday, my phone said the .42 was available. As I was away from my PC I didn't want to download a huge file over GPRS. I tried using the WiFi at home this morning and it now says there is no updates available.... has it been pulled???:con?
I had the same thing! Only that I tried again only one minute after trying the first time (I cancelled the first time because I hadn't made a backup of course). You only get one chance!?
cmlewan wrote:I had the same thing! Only that I tried again only one minute after trying the first time (I cancelled the first time because I hadn't made a backup of course). You only get one chance!?
Same here, didn't want to use my 3G data connection when I could do it at home over wifi but no update available when I was home.
can you pls share us the profile that is in Menu->Connect->Dev Manager->profiles.
