9500 + Power Safe
2 replies · 1,974 views · Started 27 October 2006
Help.....is there anyone out there who could tell me how to get a paper copy of the contents of 'Power Safe' off my phone. OK it's all backed up to a card and to the PC through PC Suite, but at the end of the day it is unreadable on the PC probable mainly due to the encryption of the data and also it does not appear that you can read the MMC either on the PC but only use the PC back for a restore. I really don't fancy having to type out the entire contents of the safe again. (By the way this copy would be kept in a very safe place and used in emergencies only by those who need to).
I have PowerSafe on my phone and I don't believe it's possible to print from it directly. However, one way is to do a screen capture of each record (would only be useful if the contents of the whole card fit on the screen).
Highlight the card and hit Ctrl-Shft-T (for full screen) and then do a Ctrl-Shft-Chr-S (to capture the screen), save all captures to a folder and then use PC Suite to copy them to your PC and print the screen shots. Do a test with one and see how it goes (it should work as I've done it before).
Not an Ideal solution (and a bit tedious too), so you should weight the effort of retyping vs. the above and see which is easier 😊 Good luck...
Many thanks for the info.I hadn't thought about a sceen dump in fact I wasn't sure how to do it, but now I will give it a go and test the speed versus retyping. Once again many thanks.
