icant intall the software to my phone, on the home page it said that 825 kb fo free space neede on your pohone, and my phone has 1200kb free , but everytime i tried to installif using pc suite, it just said that not enough space on the phone .
now i'm cofuse, anyone ???
Tennis maniac problems
Free up some more memory.....like 100kb ! Its tricky although it seems that the SIS file is installed directly, it is copied to the phone first and then installed in some way!
i ale\rady free some more space., now it has 1800 kb free on the pone , biut still wont install!!!! do i need to delete my contact as well t oplay the stupid game : :evil: hope people froom bitween will see this forum!!!!
To be honest the demo I had was working ok with even less then 1800! S o I dont think its betweens problem....
How are u trying to install it! With the Epoc Installer or with sending it to the phone?
or simply maybe the file is corrupted. where'd you get the sis? 8)
Just send the .sis file to your phone and run it from there.
i d/l the file at my-communicator.com,
now i can install half of it , cause in the middle of the op, there always a problem, saying ,your phone is disconnected 😞
im using nokia pc suite to install it on my phione .
[quote="deevonn"]i d/l the file at my-communicator.com,
im using nokia pc suite to install it on my phione .[/quote]
gee, sorry deevon, im clueless with this one. :-?
maybe u should restart ur phone 😉
Here's what you try, had that problem before...
Are you using bt or IR? Use IR double click on the IR icon in the System tray. Then just send the .sis file to your phone. You'll receive a message then just open it.
hmm, try it like this:
1.copy file to phone (it will arrive as message)
2.open this message (it will first write sth like "copying files", which means it copies the .sis file to yet another dir and then it will try to install, but most probably you will be out of mem.. that's fine)
3.delete message with .sis file
4.go to tools/manager and you should see the installation file there, run it/install it
it should install fine this way... hope it works.
