hi,
few weeks back,i heard of a software that could send sms using gprs instead of the operater service.i tried searching for one and found "TX2 software" which is good but it requires the other party to have this software also.does anyone know of a better software that works on 6680?
and is there any way yet to unlock nokia 6680?
cheerz everyone
I think that is some confusion... GPRS is network service! The prive of network provider could be by SMS or data traffic, and that way coud be lower by GPRS then SMS by SMS, but both is a pay service.
wel ya ofcrse both are pay service, but sms via gprs will way more cheaper because the charges depend on data traffic.
wel i hope someone comes up with a better software then the one mentioned above.
u guys can try the software above as well,its not very bad.just that both sending and receiving parties must have TX2 software.
thanks for your contribution nj7.
fadmani wrote:wel ya ofcrse both are pay service, but sms via gprs will way more cheaper because the charges depend on data traffic.wel i hope someone comes up with a better software then the one mentioned above.
hi This is my first time
this is very simple man, In message settings you can set it as gprs esily there is a default settings .
