Hi!
I just made a mistake, I bought a 1Gb "takeMS" RS-MMC memory card for my N70. Looks like it does not work properly, it is somewhat slow, taking minutes to load images, video capture is really bad,etc.
So, I would ask You to tell me which 1Gb card actually does work well in a N70, including video capture, so I can get one?! Please quote also, where to get it online, since I am located in Austria....
Thanks a lot!
I use a kingston myself, works really well
I can tell you to stay far away from SanDisk. Theese are really bad. The ideal MMC's are the original Nokia ones, but they are double at price.
i using transcend RS...it suit my N70 n it works in high speed...faster than other brand but slightly slower than KINGSTON...slower bout 0.5 seconds...but it is cheaper than kingston which is expensive than other brands
Thanks for the replies, but how come Steve Litchfield says explicitely: "Stay away from Kingston cards...."??? Are they working now fast or not? I am somewhat confused now....
Thanks.
