heyz ppl
my first post here , try 2 understand me .
turned the forum upside down , but didn't found the answer to my question
i live in israel , got myself a nice 7650 , in hebrew , & i hate it .
the provider here is orange . bought also the Seleq softwaer , wanted to replace my oplogo , & i did , but .... when i open the phone , it appears for only 2 seconds & dissapears . what can i do to make the da#n sunglasses to be there all the time ?
& what online stores can update my software to english , becouse here the bluetooth is illigal , & nokia israel doesn't want to do anything to help me with this hebrwe crap .
the software is 3.16 , dated 15/08/02 , NHL-2NA
thanks for the help .
Proto
Oplogo problem
The op logo is locked on your sim , so you cant change that. unless you get
a new sim card. 😞
about the oplogo, im not really sure where the problem took place. if you used seleQ properly, browsing the image then, choosing set as operator logo then the phone should reboot and you should have replaced you logo - if this is how you went about it, it should just be fine. however, there are some telecos that stored their default oplogo in the sim and if that's your case there is simply nothing you can do to change the oplogo.
sorry if that's the problem, brother.
about changing firmware, the best thing to do is go to your local Nokia Care and if you have warranty they should be able to upgrade for free. 8)
hope this helps. 😃
[quote="JyriK"]The op logo is locked on your sim , so you cant change that. unless you get
a new sim card. 😞[/quote]
dang it! you beat me to it Jy! hehe 8)
hmmm ..... & if i'll take the sim , put it in the 7110 i have somewhere , with the cable , is there any chance that i'll unlock it & the burned-in logo die ?
[quote="Proto"]hmmm ..... & if i'll take the sim , put it in the 7110 i have somewhere , with the cable , is there any chance that i'll unlock it & the burned-in logo die ?[/quote]
i doubt that will work. maybe you can do what jyrik said. if there are other telcos there, then you might want to switch - if you really want to change the op logo.
[quote="seanmiguel"]
i doubt that will work. maybe you can do what jyrik said. if there are other telcos there, then you might want to switch - if you really want to change the op logo.[/quote]
somehow i doubt that.
