Hi May I know which version of SmartMovie Converter of this? Coz its a N70. I just bought a new N70 3 days back.
So which version is suitable for N70?
Mine is:
V 5.0616.2.0.3
24-04-06
RM-84
THANKS
Mine is:
V 5.0616.2.0.3
24-04-06
RM-84
THANKS
You vave to use the S60 version, which seems to be the one from the screenshot. If not, select Preferences and go to combobox where the displays resolutions can be changed.
It looks like you have an older version of the converter. Get the new one and you'll find optimizations for the N70
