Problems with sending pictures from 7650 to my EMAIL addess!
23 replies · 5,281 views · Started 11 December 2002
when i try to mail a pictures from my phone to my email address; i don�t get the file as an attachment, but just text.
here�s a litt example of how it looks..
X-Mailer:Symbian OS Email Version 6.1
MIME-Version: 1.0
Content-Language: i-default
Content-Type: multipart/mixed;
boundary="EPOC32-+G-0fFTWcNpkwV6g-qttj--kW06xLcr9cwlJ-csr_fBRGDBw"
This is a MIME Message
--EPOC32-+G-0fFTWcNpkwV6g-qttj--kW06xLcr9cwlJ-csr_fBRGDBw
Content-Type: text/plain; charset=UTF-8
Content-Disposition: inline
Content-Transfer-Encoding: quoted-printable
G
Content-Type: application/octet-stream
Content-Disposition: attachment;
filename="Bilde(01).jpg"
Content-Transfer-Encoding: base64
/9j/4AAQSkZJRgABAQAAAQABAAD//gBJTm9raWEgTW9iaWxlIFBob25lcyBM
dGQuCk5va2lhNzY1MAowNC4xMi4yMDAyCjE4OjI0OjQ3Ck1vZGU9MQogMy4x
MgoxLjL/2wBDAAkJCQkKCQsLDAwNCw0LDQ8QEBEUFBQUFBQUFBQZICAgICA
++++ etc etc etc
how can i fix this?? i�ve tried sending it to different email adresses, but the same thing happens 😞
please help me!
kim
nope, haven�t got zipman 😞
but there�s gotta be a setting for this. or something?
kim
you don't need zipman to be able to send some attachments to your e-mail ad! for example; you got a picture, go to the picture and then select send - via e-mail. give your e-mail ad and if you want you can put some text on it and then send it! as easy as ABC !!
one question though! are you using a GPRS internet account?? not that GPRS WAP Account! and you should use your providers smtp address for sending mails !!
i know how to send a picture etc. look at the first post at this thread, that�s what i get when trying.
i use GPRS with the internet setting. i can recieve mails, and send. the only thing is that i don�t get attachments correctly, its just text included in the mail..
take a look at post#01 in the thread, see if you can figure it out 😊
thanks..
kim
[quote="keem1"]when i try to mail a pictures from my phone to my email address; i don�t get the file as an attachment, but just text.
MIME-Version: 1.0
G
++++ etc etc etc
please help me!
kim[/quote]
it works for me, tell me exactly what u did to send the image to ur email?
did u add an attachment, just send it how it was or did u insert picture?
[quote="555"]
This is a MIME Message[/quote]
wtf where the hell this come from
silly cut command 😃
i�ve tried "make a new message", than choose e-mail, and just added a "picture" there..
i�ve also tried going into the "pictures" directory, and choose "send" via email..
i get the same type of email nomatter what i do :/
kim
strange, i have tried all the wayz and they all work fine.
maybe u should try the "add attachment" option and see if this works for you.
Looks like somewhere along the line the e-mail headers are getting rewritten and you mail getting converted into text, if it happens to all addresses you send to then it points to it being done by the outgoing server.
What email server are you using to send thru - can you try another?
Send a picture to me [email protected] and I'll have a closer look at it.
maybe it has something to do with the central i�m sending through?
or are there any sending options that i should go through?
damn 😞 it would have been so cool if it worked..
kim
Hi kim.
It looks like your outgoing server is to blame - it's rewriting the headers to read 'Content-Type: text/plain' which is causing your e-mail, including attachments, to display as text.
You need to find another mailserver to send thru - or speak to the current one and ask them about it.
I always send images through e-mail rather than MMS and have never had a problem with the attachments, I can see no setting on the phone what can do this to the e-mails...
Best
Will
You have your telephone operators email service?
Might be, that they would like you to use MMS and pay huge sums for it 😃
and have disabled/screwed up the email attachment sending like willbrady
said.
i�ve just made a new email at "hotmail". so that i can RECIEVE mails from that account i�m using right now, and maybe SEND via hotmail 😊 (if it works)
but how do i find the settings from hotmail? pop3 etc...
kim
Hotmail is http not pop3
In it's earlydays you could use pop.hotmail.com but I doubt that would still work..
Yeah. Hotmail and Yahoo wont work anymore for POP3. (yahoo has a paid service for POP ..though)
You might want to try Hotpop. Its free and pretty simple
Goodluck
[quote="keem1"]
[/quote]
The problem is in this part. Your mail client does not decode that base64 encoded part correctly.
Sure but in the first post it clearly said that they have sent to other e-mail address too and none of them worked so unless all Kim's mates have e-mail clients that do not read base64 then it's not that - plus the fact that the actual message includes the 'html' coding and headers points to the mail being delivered in text format rather than simply being read in text format.
Plus the e-mail Kim sent me incuded the headers as part of the actual e-mail, which points to the origal header being rewritten - the rewritten header showed the Content-Type: as text, it should have been 'multipart'
Try www.HotPOP.com. It's free mail forwarding.
The reason why I said about the zipman is for the e-mail not to automatically be modified because of the picture file extension.
Your e-mail is quarantined in effect.
i tried sending a picture from phone to email via HotPop, but the same thing happens..
kim
You should take up the issue with your operator, as it seems more of some kind of corruption at the gateway. Anyone else on ur network with the same problem?
amoung my friends, i�m the only one who�s crazy enough to spend that amount on a phone 😊
(probably the only sucker who has got money enough too, hehe)
anyone from norway, who�s using "djuice" for GPRS??
(think i�ma try finding another "server" for GPRS, and see how it works with emails. its strange, because it recieves messages with pictures perfectly etc..)
hmm.. confused..
kim
