I did a FOTA Update last night!
24 replies · 6,289 views · Started 30 October 2006
It said there was an update, I was previously on the Euro 1 update of v4 which ends in .41, the update has taken me to .42 and it didn't delete any phonebook entries or messages etc, well pleased :icon14:
Hooah!
Just updated my precious N80 with FOTA. Worked great just as You said tomnufc.
*#0000# Now reveals:
V4.0623.0.42
20-09-2006
RM-92
Nokia N80 (03).
But I have no clue what this Firmware update fixed. Anyone?
/ Dozer
I haven't noticed any changes really but it's just nice to see the FOTA working properly, and the fact it doesn't delete an user data is a nice bonus 😊
Ungjaevel wrote:Stoopid question, sorry.
How do I update OTA?
Use the Device Manager function in the Connections menu to check for upgrades - best to use over a wifi connection for speed & cost issues
Ungjaevel wrote:Mille gracie, just updated without problemas...
De nada 😊
Per the change log listed by Symbian Freak at: http://www.symbian-freak.com/quides/firmware/logs/n80_new_firmware_m1.htm
FOTA:
  • Camera forward compatibility fix for FOTA update
  • Sync agent forward compatibility fix for FOTA update
Messaging:
  • SMS Sending Delay
Display:
  • Correction for mis-read of ASIC version causing pink display.
TazUk wrote:Use the Device Manager function in the Connections menu to check for upgrades - best to use over a wifi connection for speed & cost issues
In my device manager, there are no servers defined.
Do you know if FOTA is supported by Vodafone UK?
And if so, what server settings do I need to use?
Cheers
SL
superleccy wrote:In my device manager, there are no servers defined.
Cheers
SL
In my Device Manager I have a (no server profiles defined) message in the main profiles tab, however I have a Default Profile of "Nokia" under the Settings Menu option within Device Manager itself. Is this not the case for you?
I can't seem to access this Nokia profile to retrieve the settings unfortunately.
FOTA should be independent of network - it's a device level mechanism that lets Nokia host (branded, if required) firmware for download. It might be worth checking with Vodafone if you can find a member of customer services who understands the elements involved 🙄
I am on Vodafone UK, and had previously Phoenix'd my firmware to a generic V4.0623.0.41. I have just performed a download and update OTA, after checking for updates via the device manager, I only had to select my usual Vodafone GPRS connection and all was fine.
Once downloaded (took seconds over 3G) I had to sit and watch as an 'Updating' progress bar crept ever so slowly across the screen. Probably took 3-4mins, but after the update the phone started back up with all user settings, and more importantly software and associated licenses still intact.
Software that participated in this upgrade (and survived) includes:
Profimail
TomTom
Call Manager
Photorite SP
AgileMessenger
HandySafe
Mobile Google Maps
when i try to check for update either with 3g or wifi i get an authenication error, check user name or password. i'm on the three network.
TazUk wrote:In my Device Manager I have a (no server profiles defined) message in the main profiles tab, however I have a Default Profile of "Nokia" under the Settings Menu option within Device Manager itself. Is this not the case for you?
No, I do not have that facility. I also get the "no server profiles defined" message, but when I select the right softkey ("options"😉 the only choices I get are "New Server Profile", "Help" and "Exit"😉. I wonder if this is a V4 feature. I'm still on V3.
I suppose that even if I could use do a FOTA update, it still wouldn't be any good for me because clearly there isn't yet a UK Voda V4 firmware available yet (because if there was it'd be available via their PC update tool). :frown: 😡
Thanks for trying anyway.
SL
i tried my n80 with nokias update software yesterday aswell, but with different results to what everyone else has got.
download of update took ages! on an 8meg line took nearly 40 mins! and then when it tried updating, also took forever. the fone turned off, i thought was rebooting like when using pheonix, but it never turned back on. a few minutes later nokia updater says software update failed!
now i have a lovely back n80 paperweight! its just dead, wont turn on, nothing *sigh*, and what makes it worse is that i backed all my pics contacts to sim just before, and when i put sim in another fone, nothing!! seems they have disappeared aswell
superleccy wrote:I wonder if this is a V4 feature. I'm still on V3.
You wonder correctly, the FOTA option doesn't appear until v4.
I clicked on update (fota) and it said there was one. But being paranoid I cancelled it, took my memory card out just incase it erased anything and tried to update again. It said there wasnt one??
Anyone know how to get the update that has disappeared??
Hi Folks,
i tried to do a FOTA last night using WLAN. Its says "OPERATION CANCELLED BY SERVER". Every time i tried, i am getting this error....is there a workaround where i can bypass this and get it updated to .42 using FOTA...
Pls help!
vin_eme wrote:Hi Folks,
Pls help!
Use WiFi
Cyclone wrote:I clicked on update (fota) and it said there was one. But being paranoid I canceled it, took my memory card out just in case it erased anything and tried to update again. It said there wasn't one??
This happened to me. I went to update then read about the person who installed firmware they already had and the problems that caused them so I canceled it to check the version again. When I re-ran the update I got told there wasn't one.
However, a couple of days later it 'found' it again and updated correctly. So the best I can tell you is to wait a day or so and give it another go.
The_Vindicator wrote:when i try to check for update either with 3g or wifi i get an authenication error, check user name or password. i'm on the three network.
I get the same message, my firmware is:
V.4.0623.0.41
26-07-2006
RM-92
Nokia N80 (45.02)
