as title.
thanks
as title.
thanks
Try: * + 3 + Green Key and power on. But some people said that works and others don�t. Try...
*#7370#
tried it a few time's, and nothing!!
thanks tho!
thanks bowman... trying it now!!
From Sticky: Useful links and FAQs:
Phone Reset - In both case, the phone will ask you a confirmation and you will have to enter a security code (12345 by default)
Files and applications stored on E: drive are not be affected by these sequences.
Normal Reset *#7780# : Restores ini files from rom but preserves user data (photos, 3rd party apps etc) to factory settings
Deep Reset *#7370# : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
For Symbian OS 7 and higher there is a third method: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. The phone will start the formatting process without confirmation! Files and applications stored on E: drive are not be affected by this.
The stickys are usuallly there for a reason! 😊
thanks people. all fixed with a hard reset!!
