I've had my E70 for a couple of weeks now, including a week on holiday. For the first couple of days, sending emails was fine, but now whenever I send an email it sits in my Outbox with a status of "Queued". I can't arm-wrestle the E70 to send it no matter what ruses I try. I suspect I may have inadvertently achanged an obscure setting, but I'll be ****ed if I can find it.
Does anyone have any ideas?
TIA,
Chris
The outgoing SMTP server name in the mailbox settings under (Messaging > Options > Settings)?
It worked :icon14: 😊
I had indeed managed to remove the outgoing server settings from one of my accounts, and change the port number on the other. Now I'm wondering if I can really use the word "inadvertently" 😉
Thanks again
Chris
Perhaps you forgot the keypad lock and the phone did that on its own in your pocket. 😉 Main thing is that you've fixed the settings now.
