can somebody teach me how to reformat my n73 the hard and the soft format. tnx. is there a new firmware available right now?
reformat n73
For a hard format use *#7370# but I'm not sure about the other one apart from the Reset Original phone settings. 😉
*#7780# - the other part...
There is another key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds.
For more information, check out my blog posting here, http://www.s60tips.com/2006/08/11/some-more-secret-codes-for-s60-phones/
None of those codes and tricks work correctly with S60 v3.
Currently there is no known way to fully re-format an N73.
