Hi there,
Does N80 supports any bluetooth headset that can play music in stereo? My understanding is N80 doesn't really support A2DP. Has anyone managed to play stereo music via some bluetooth headset?
Any expert opinion?
Hi there,
Any expert opinion?
No. N80 doesn�t support A2DP. Only 8800 and the new music ones, like 5300 and others.
Are you sure?
N80 is listed as A2DP complient by Motorola's HT820 - which I have - and it do seems to play in stereo.
my n80 doesnt play in stereo with my HT820. I do not think its stereo as the sound quality is so much inferior compared to my W850i. definitely sounds mono on the n80. did you do any tweaking?
I'm using the v4 APAC firmware and i emailed NOkia who informed that there is no A2DP support for the N80. other region maybe?
VetDuarte wrote:Are you sure?
I�ve read in a magazine that you get stereo support by installing a driver/application called MSI BluePlayer. You can download it from the MSI website. Search for Blueplayer for symbian S60 ver 3.
I don�t have a stereo headset, so I can�t test it...
egaf56 wrote:I�ve read in a magazine that you get stereo support by installing a driver/application called MSI BluePlayer. You can download it from the MSI website. Search for Blueplayer for symbian S60 ver 3.
A2DP must be on ROM... is a bluetooth profile missing on N80. Installed with third party SW, I don�t know:con?
There is a set of Bluetooth headphones I read about recently that allow A2DP profile on phones. They come with an adapter that plugs into the bottom of the phone to make them work in stereo. They are import only I think, just can't remember where I saw them or what they are called!
Anyone know, coz I'm definately getting them once I get some money!
