i have a 6680 and it wont load the os the phone lights up and the word nokia comes up but wont boot into the os(just keeps trying to boot). is there any way of flashing it without it booting into the os ?! or anything else i can try as this seems like a software error. and yes ive taken the bteerey and mem card out and still the same :con?
6680 wont' boot
Flashing is a bigger step, try formatting it first. while its turned off, press and hold the * key, 3 key and green call key while you turn the phone on. keep the keys pressed while it boots up. if its just some software problem, your phone will boot up and ask you to set location, date and time. if it doesn't boot up then you'll have to get it flashed from Nokia Service Centre.
In either case, you'll lose all data you have on your phone memory.
