a friend showed me his new cell phone i forgot the unit. but he call totaly watch tv in his c.p. he is using a software (roktv) but when i tried it in my n-gage deck, the program is running but still i cant watch. does any body have a better program than roktv or any one can help me use this program. here's the site where you can download the program www.rok.tv.com
watching t.v in n-gage
RokTV work well on N-Gage, with SPP - use the PC net connection. Is just do what they said on their site.
:con? Can I install games in my n-gage QD without bluethoot adaptor ?
Yes, no problem. Take the MMC card, put it on a card reader, copy the files to the card and then install.
i dont have a QD i was wrong ... is just Nokia N-Gage ... and i connect at PC with cable , i copy symbian and java app but i cant instal them on my mobile.
Same way, only even more easy, because N-Gage original can be direct connected to the PC on USB mode. Use FExplorer to browse the card and run the installation file.
hi friends
can i used roktvwithout gprs??
reply me im waiting.
Yes, no problem. Just connect the N-Gage to PC by Bluetooth (the PC must have an Internet Connection, of course) and by IP Passtrough is direct.
nj7 wrote:Yes, no problem. Just connect the N-Gage to PC by Bluetooth (the PC must have an Internet Connection, of course) and by IP Passtrough is direct.
thankz u
should i have to install any software in my mobile to connect it?
just only roktv. then i can used it?
No, nothing special. Just do that: http://www.russellbeattie.com/notebook/1001649.html
