Hi... Is there a way to use my PC to let my e70 access the Web thru the USB cable? I don't have a WiFi/Bluetooth antenna, so I can't create a hotspot... any ideas?
Thanks,
Ricky
Thanks,
Ricky
Look into "IP passthrough" in the E70 User Guide, and for that download Nokia Network Bridge from Forum Nokia: http://forum.nokia.com
RickyS wrote:Hi... Is there a way to use my PC to let my e70 access the Web thru the USB cable? I don't have a WiFi/Bluetooth antenna, so I can't create a hotspot... any ideas?
See here for step-by-step instructions: http://www.allaboutsymbian.com/forum//forum/thread/48901/
I'd recommend to invest in a wifi router though. They're not that expensive and being able to check your emails, check the latest posts on your favourites blogs and forums, download and listen to your podcasts, have the weather updated automatically every morning before you're off to work, all that without having to bother even to switch on your PC is a killer.
elp wrote:See here for step-by-step instructions: http://www.allaboutsymbian.com/forum//forum/thread/48901/I'd recommend to invest in a wifi router though. They're not that expensive and being able to check your emails, check the latest posts on your favourites blogs and forums, download and listen to your podcasts, have the weather updated automatically every morning before you're off to work, all that without having to bother even to switch on your PC is a killer.
Thanks, people! :icon14:
