i had my HANDY CLOCK n HANDY SAFE installed in N70...i found that they had gone after i upgrade my firmware....i am sad with it because i forget the registration key when i bought last time...i wish that sumone can help me...i need the code....thanks
Handy Code
The developer can provide you the codes again, if you lost them (however, check your email that you supplied when you bought it & next time save such codes somewhere for sure).
If you got it from Handango then log in using your email address, request your password then log it when you have it. You should find the orginial download plus your reg code.
Good Luck.
Vim
